Aritech CS350 User Manual
Guest Racer25
Guest Racer25
Hi Guys
Forgive me if posting in wrong section, I am looking for a user manual for the Aritech CS350, wish to inhibit a zone as I am 90% certain that a sensor is faulty and the engineer won't be out for a week.
Also its something I should really, Aritech also pulled out of Ireland so can't contact them direct.
Thanks
Rob
hello
does it say "arm menu" when you type your code in if so press the down arrow once it will say "inhibit" press tick put the zone no you want to inhibit and press tick then zone is inhibited FOR ONE SET ONLY!! hope this helps
kevin
Quote of the day: A good friend will bail you out of jail but a true friend will be sitting next to you saying damn we fcuked up!!!
management treat us like mushrooms!! keep us in the dark and feed us bullsiht!!!
hi aritech are still in ireland
GE Security Ireland · 2007/2008 Orchard Avenue, CityWest Business Campus,, El-Dublin 24 · Tel. 353/1-4699760· Fax 353/1-4699761/2 · Country Manager: Geoffrey McIvor ·
Guest Racer25
Hi
I can get the inhibit menu to come up but when i select the zone 03 or 3 (it comes up 03 but I have tried both) it comes up not allowed.
I press 0 - down arrow - 7 and the system starts arming, I press up arrow and I get the inhibit menu and press 03 or 3 and i get not allowed???
Not sure what I am doing wrong about 20 minutes to 2 hours later the alarm goes off.
Thanks
Rob
  • 2 weeks later...
Guest npresto
I'm having the same problems myself.
I bought a house recently with a CS350 alarm installed.
I come home from work and the alarm is going off.
The panel says that it is from a PIR in zone 03.
I think the zone is faulty but when I try to access the inhibit menu
the panel says access is denied.
I only have 2 arming codes: (0, Up Arrow 4) and (0, Up Arrow 5)
and a code to dis-arm the alarm.
I think I need to reset the users/engineers code to
grant access to the inhibit menu.
Any help would be grateful.
mailto:noelpreston@hotmail.com
Regards
Noel
