Guest fergmeister Posted March 15, 2004 Posted March 15, 2004 To anyone who can help, I have an Optima 2 Plus home alarm system (10 years old) which has suddenly stopped working. There is now a continuous bleep from the keypad and the keypad itself won't accept either my personal code or the factory setting code. I have been advised it could be that the battery in the control panel is dead but that, if I try to replace it myself, it could set off the alarm and I may not be able to reset it (upsetting for my neighbours). Q Does this sytem have some sort of tamper protection that will set of the alarm if I try to open the control box to replace the battery? What should I do (other than call out an engineer)? , Fergmeister.
Guest simmo Posted March 15, 2004 Posted March 15, 2004 This post has been replied to under the heading optima rf alarms. Simmo B)
Guest lev Posted March 16, 2004 Posted March 16, 2004 Peter is correct If the battery hasnt been changed it is possible it has done damage to a component in the charging circuit. Nearest equivalent panel is the Opptima G3 8 zone. Make sure battery is changed at least every 3 to 4 years.
