Guest gordonbain Posted March 17, 2004 Posted March 17, 2004 I have just moved into a new building with a Securicor granly system installed. It it quite a large box with a key pad on the left and a key to lock the keypad. it does have an Ititial shorrock sticker on the box. unable to find any model number - apart from a valiant board in it. The problem is that i don't have a code for it. Is their a way of reprograming the alarm? Thanks for reading Gordon
Guest gordonbain Posted March 17, 2004 Posted March 17, 2004 how do you default the system? It it that complicated? antone got instruction or tell me how to do it? Thanx
Guest dale Posted March 17, 2004 Posted March 17, 2004 Im afraid this site doesnt give out installation manuals. I suggest you call a local engineer to come and default the system for you or advice you on your security needs. Dale
ian.cant Posted March 18, 2004 Posted March 18, 2004 With that panel its quite complicated, if your not an ex Securicor engineer or an Initial engeer dont waste your time! I suggest you contact your local Initial branch or its a case of rip it out and start again, as the panel is basically obsolete i would choose the latter option.
Guest HomeSecurityServicesUK Posted March 20, 2004 Posted March 20, 2004 As the above post says this panel is obsolete. I would consider starting from scratch. Spare parts are few and far between.
Guest stu8 Posted May 26, 2004 Posted May 26, 2004 As these panels are Securicor home made hardly anyone will be able to reprog them I sugest you contact your local Initial Branch Stu8 Initial Eng..
Selsport69 Posted May 30, 2004 Posted May 30, 2004 Even then going by the Genesis it may not power back up with defaults. I would rip it out. The only thing is you may need to rewire if there is white mli boxes about the place. Kev
