Guest TONIC Posted March 17, 2004 Posted March 17, 2004 HI NEED HELP IN SETTING UP A GALAXY 16+ ON BT REDCARE ARC HAS NO INFO THAT CAN HELP ME NEITHER DOES ANY OTHER ENGINEER I KNOW JUST NEED INFO REGARDING DIGI PROGRAMMING.
bellman Posted March 17, 2004 Posted March 17, 2004 Gal 16+ takes a standard plug on redcare stu, no difference in programming a chip for it than any other redcare stu. you can set what pins you want in menu 13 (communications2) option 5 (STU triggers) dont forget to enable the stu though in menu 13 option 4 (STU options) Hope this helps. Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
Guest TONIC Posted March 17, 2004 Posted March 17, 2004 I KNEW I NEEDED SOME THING LIKE THAT I'VE FITTED GSM DUALCOM WITHOUT PROBS BUT THIS REDCARE LARK! WILL MY SUPPLYER BE ABLE TO SORT ME ONE OF THESE OUT? MANY THANKS
Service Engineer Posted March 17, 2004 Posted March 17, 2004 You dont NEED to have the plug on Stu, any STU will work. You just program the outputs to what you want as Bellman states above. ........................................................ Dave Partridge (Romec Service Engineer)
bellman Posted March 17, 2004 Posted March 17, 2004 Dave is quite correct, any stu will wire up to the gal16+ I just find it easier to plug one on don't have to bugger about setting up line fault connections and the like, just plug, prog, up it and go Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
norman Posted March 19, 2004 Posted March 19, 2004 Hi Bellman, Plug on STU's & Digi's are now Non Stock Listed within //.National Installer.// so you better start practising wiring the stand alone ones regards... Nothing is foolproof to a sufficiently talented fool.
bellman Posted March 19, 2004 Posted March 19, 2004 Hi Norm, I'd better be frugal with my existing stocks then I ordered some from Letchworth only a few weeks ago, when did they discontinue them? Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
Guest TONIC Posted March 20, 2004 Posted March 20, 2004 Got myself sorted now Theres a unit called veritus which plugs on to the board you still have to add your nvm chip, but the arc does all the downloading so you dont have to programe the outputs or line fail etc price was reasonable too.
bellman Posted March 20, 2004 Posted March 20, 2004 Yup, that's the STU i was on about earlier... You STILL need to programm the pins, unless the ARC has dialled into the panel to remotely program it. Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
Guest TONIC Posted March 24, 2004 Posted March 24, 2004 yep bellman the arc just 'up stu'd' everything was on the nvm chip no probs the 3gstu was expnsiveeeeee though more than the soddin panel
