Amps Posted December 6, 2011 Share Posted December 6, 2011 4. CIRCUIT RESISTANCE. Pass / Fail. Yes / No. Check resistance against records Check circuits clear of earth faults You check every circuit resistance with a meter or if possible resistance given by the panel? What if the system has 50+ ccts? earth faults? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/176-maintenance-checklist/page/3/#findComment-279080 Share on other sites More sharing options...
Able Alarm Posted December 6, 2011 Share Posted December 6, 2011 i an lucky that 85 percent of customers are domestic, other 15 percent commercial with under 30 devices. Yes i test all Ccts. my customers pay me well for my services and i am happy to get the work. i dont have to rush and its very no so often i have to return between visits. My passing comment to customers is "hope not to see you for 12 months" but there all no that i will be there if needed. AbleAlarmMan Able Alarm Ltd Link to comment https://www.thesecurityinstaller.co.uk/community/topic/176-maintenance-checklist/page/3/#findComment-279082 Share on other sites More sharing options...
sixwheeledbeast Posted December 6, 2011 Share Posted December 6, 2011 i an lucky that 85 percent of customers are domestic, other 15 percent commercial with under 30 devices. You can tell by your forms. Some of our jobs can have 12 or more PSU's to check, with 2 eight zone expanders in each PSU. There is no space on your forms for more than one PSU. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/176-maintenance-checklist/page/3/#findComment-279083 Share on other sites More sharing options...
Able Alarm Posted December 6, 2011 Share Posted December 6, 2011 I developed this form for the size of my system but there is no reason additional sheets for larger systems couldnt be used AbleAlarmMan Able Alarm Ltd Link to comment https://www.thesecurityinstaller.co.uk/community/topic/176-maintenance-checklist/page/3/#findComment-279095 Share on other sites More sharing options...
antinode Posted December 6, 2011 Share Posted December 6, 2011 Have you ever actually found any high resistances/shorts to earth or other cable faults through doing these readings on a service? Not having a go, just curious as to how other people work. I personally don't take circuit resistances on a routine service visit unless there is a good reason to (recent false alarm etc). Most of our jobs are FSL wired, so it would require removal of resistors to get a true resistance of the cable. Way too much faffing in my opinion... Trade Member Link to comment https://www.thesecurityinstaller.co.uk/community/topic/176-maintenance-checklist/page/3/#findComment-279104 Share on other sites More sharing options...
alterEGO Posted December 6, 2011 Share Posted December 6, 2011 Have you ever actually found any high resistances/shorts to earth or other cable faults through doing these readings on a service? Not having a go, just curious as to how other people work. I personally don't take circuit resistances on a routine service visit unless there is a good reason to (recent false alarm etc). Most of our jobs are FSL wired, so it would require removal of resistors to get a true resistance of the cable. Way too much faffing in my opinion... QFA Link to comment https://www.thesecurityinstaller.co.uk/community/topic/176-maintenance-checklist/page/3/#findComment-279105 Share on other sites More sharing options...
fozzies Posted December 7, 2011 Share Posted December 7, 2011 Have you ever actually found any high resistances/shorts to earth or other cable faults through doing these readings on a service? Not having a go, just curious as to how other people work. I personally don't take circuit resistances on a routine service visit unless there is a good reason to (recent false alarm etc). Most of our jobs are FSL wired, so it would require removal of resistors to get a true resistance of the cable. Way too much faffing in my opinion... i have! ( once or twice ) Link to comment https://www.thesecurityinstaller.co.uk/community/topic/176-maintenance-checklist/page/3/#findComment-279110 Share on other sites More sharing options...
Ronnie Posted December 7, 2011 Share Posted December 7, 2011 Have you ever actually found any high resistances/shorts to earth or other cable faults through doing these readings on a service? Not having a go, just curious as to how other people work. I personally don't take circuit resistances on a routine service visit unless there is a good reason to (recent false alarm etc). Most of our jobs are FSL wired, so it would require removal of resistors to get a true resistance of the cable. Way too much faffing in my opinion... agreed, taking out cores all the time will lead to them not going back in properly at some point. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/176-maintenance-checklist/page/3/#findComment-279114 Share on other sites More sharing options...
MrHappy Posted December 7, 2011 Share Posted December 7, 2011 when we where doubled poled all circuits where measured every visit, the advent of employess made us stop doing this as they caused more problems than they prevented. Mr Veritas God Link to comment https://www.thesecurityinstaller.co.uk/community/topic/176-maintenance-checklist/page/3/#findComment-279115 Share on other sites More sharing options...
whistle Posted December 7, 2011 Share Posted December 7, 2011 when we where doubled poled all circuits where measured every visit, the advent of employess made us stop doing this as they caused more problems than they prevented. I can agree with that..... Link to comment https://www.thesecurityinstaller.co.uk/community/topic/176-maintenance-checklist/page/3/#findComment-279122 Share on other sites More sharing options...
