Guest SteveJ Posted March 20, 2004 Posted March 20, 2004 I have recently moved into this house and it came with an Accenta8 alarm but sadly no instructions. In the past day my tamper light keeps flashing and i cannot seem to be able to clear it and now today when i open one of the internal doors the internal audible makes its canary noise. Is there anyone knowledgeable out there that can help please?
Guest lev Posted March 21, 2004 Posted March 21, 2004 You will probably find the user guide for the old Accenta 8 is not on the ADE website, you will only find the newer Accenta G3 which has a different service timer programming. To reset all chime zones. From day mode press CHIME then 0 then RESET.
Guest SteveJ Posted March 21, 2004 Posted March 21, 2004 Very many thanks to all above who have replied and have the knowledge to steer a someone with absolutely no knowledge in the right direction. Big thanks to lev, that worked within seconds. I have found this site to be very useful and give it full marks and will be recommending it to friends who may be needing similar help, SteveJ
