Locking My Engineer Code
martlewis
i do not know about this particular panel, i would imagine so , its a fairly modern panel (forgive if this is wronge)
but i ask myself, why do you want to lock in the engineers code.
i would simply change it from factory default and not tell anybody the code.
locking in the code may cause you problems later if you forget it and want to make changes, because it is locked in, the panel will not be able to be restored back to factory default.
if the engineer code is not locked in then the factory defaults can be restored at a later.
remember this is your panel and once the code has being changed off factory set, then only the person who knows the code can get back in to change the programming. :)
I don't think you should be aloud to lock in the engineer code (except possibly on rented system ) as the panel is the customers property and at the end of the day if you don't look after him its your own fault he moves to another Installer .
www.AllanMoncrieffAlarms.com
Guest anguscanplay
been discussed to death so many times some do it many dont its up to the installer
HI
YES YOU CAN LOCK THE ENGINEER CODE ON THIS PANEL. I DON'T LIKE THIS FEATURE MUCH AS IF ITS NOT RENTED AND THE CUSTOMER WANTS TO USE ANOTHER COMPANY IT CAUSES A FEW PROBLEMS.
cheers
MRG
Guest anguscanplay
Guest anguscanplay
it is possible some do it some dont but
this is the public forum so we are unable to tell you how to do it or how to get round a locked code sorry
Guest anguscanplay
were been very polite arnt we anyway the topic should be closed now
:closed:
