Powering Control Panel From Spur To Socket
username132
Someone on another forum said that they installed an alarm with a spur to a socket. Mum's house has JUST been redecorated (carpets due in a few days) so we don't want to go smashing holes through things. Does anyone else have experience of powering from a spur to the nearest socket? Will the alarm go off if a hoover is turned on?
Not if the wiring is done properly (i.e. to standards) and the hoover isn't seriously faulty.
There are also various filters and spike suppressors available to help with electrical interference (I have one on my alarm).
I think (pro's correct me) the alarm is unlikely to be triggered by even a bad electrical problem when in day mode (which it will be if you're there hoovering), though you may get a tamper indication.
Guest anguscanplay
its done hundreds of times a day with no problems
BUT
are you competant enough for the job
are you aware of the part p requirments
are you able to certify the install
if not it is always the best advise to get a proffesional in to connect the 240v ac
