tododo Posted March 27, 2007 Posted March 27, 2007 Hi all I was looking to get one of these http://www.alertelectrical.com/Burglar-Ala...--Kit-KIT10.asp However it is probably a bit over the top for what we need.............I liked the idea of this panel because of the speech and text dialling addition and also the fanciness of flush mount remote keypad and keytags But it is probably a bit too much for an average 3 bedroom semi - thats also in the middle or redecoration Im now looking at something like this http://www.brewtime.co.uk/product-detail.asp?d=995 A bit more reasonable.........and probably easier to install Is it expandable at all......ie can you add one of those listenening devices to dial in and listen if you are getting robbed Thanks guys for any advice
Service Engineer Posted March 27, 2007 Posted March 27, 2007 Go for the 1st kit, as buying the 2nd kit and adding a dialer later will work out way more expensive. ........................................................ Dave Partridge (Romec Service Engineer)
tododo Posted March 27, 2007 Author Posted March 27, 2007 The second one does actually come with a speech and text dialler
Service Engineer Posted March 27, 2007 Posted March 27, 2007 Go for the 1st kit, as buying the 2nd kit and adding a dialer later will work out way more expensive. Oh yeah, the same kit excepting the keypad, dummy bellbox, and prox tags on the 1st, and a PA Button and a 7Ah on the 2nd. The 2nd then will be ok. But if you don't need the speech/text dialler because you want the facillity to listen in, why not ask them how much to upgrade the dialer on their kit to a Vocaliser complete with mic. ........................................................ Dave Partridge (Romec Service Engineer)
