tone Posted March 30, 2007 Posted March 30, 2007 Hi all This is my first post - and a question: I have acquired a fairly old VCL dome (date code 0285). Obvious markings are the numbers VC430V4 printed on the larger of the two circuit boards & VC431 on the smaller board. There are no DIP switches but there is a slide switch on the camera module circuit board marked INT-OFF-EXT. A ferrite transformer on the larger circuit board is labelled COAX/LL. More important than identifying the type is the need to identify the wiring to the dome: the dome module itself has male DIN? connector; this plugs into a female that is concentric with an alloy tube that attaches to the module via a bayonet. The other end of the alloy tube has a female DIN socket. The dome came with a plug to fit this that has the following wires attached: - a slim coax (obviously video & perhaps data) - five single wires: red, black, blue, yellow and green If you can help I need to identify the wires (especially those that supply power), the power supply voltage, and whether it's an AC or DC supply. This is for hobby use / curiosity only. Thanks in advance.
Service Engineer Posted April 4, 2007 Posted April 4, 2007 The VC430VA board is fitted in the VCL Orbiter Microsphere. It should have 2 dil switches on the board 1x8 way and 1x4 way. 8 way plug: 1 = 24VAC Green 2 = 24VAC Red 3 = Data + Blue 4 = Data - Yellow 5 = Video GND Coax Screen 6 = Video Signal Coax Core 7 = Not Used 8 = Not Used ........................................................ Dave Partridge (Romec Service Engineer)
tone Posted April 5, 2007 Author Posted April 5, 2007 Hi,High resolution pictures of the PCB please uski Thanks for the response: pics attached. I found a 4-way dip switch hiding under a heatsink & there's a place for an 8-way that's never been fitted. Tony
tone Posted April 5, 2007 Author Posted April 5, 2007 The VC430VA board is fitted in the VCL Orbiter Microsphere.It should have 2 dil switches on the board 1x8 way and 1x4 way. 8 way plug: 1 = 24VAC Green 2 = 24VAC Red 3 = Data + Blue 4 = Data - Yellow 5 = Video GND Coax Screen 6 = Video Signal Coax Core 7 = Not Used 8 = Not Used Briiliant - thanks!! There's also a black wire - data ground possibly - that I can identify easily now I have the rest. I know that VCL protocols aren't in the public domain but do you know if anyone has managed to control one of these domes from a PC? Thanks again Tony
tone Posted April 5, 2007 Author Posted April 5, 2007 You are pluggin the dome into the housing? I don't have the ceiling hanger/rose/terminal block/whatever the camera hung from but I do have the housing - it's dismantled so I can see the boards, camera, etc whilst sorting out the connections.
soportecsmx Posted October 31, 2007 Posted October 31, 2007 Hello I have a card VC430V4, that it can help me to form it, direction, control of movement, speed I try it to form for control through Protocol RS485 or Pelco D Appreciating its Attention Hi allThis is my first post - and a question: I have acquired a fairly old VCL dome (date code 0285). Obvious markings are the numbers VC430V4 printed on the larger of the two circuit boards & VC431 on the smaller board. There are no DIP switches but there is a slide switch on the camera module circuit board marked INT-OFF-EXT. A ferrite transformer on the larger circuit board is labelled COAX/LL. More important than identifying the type is the need to identify the wiring to the dome: the dome module itself has male DIN? connector; this plugs into a female that is concentric with an alloy tube that attaches to the module via a bayonet. The other end of the alloy tube has a female DIN socket. The dome came with a plug to fit this that has the following wires attached: - a slim coax (obviously video & perhaps data) - five single wires: red, black, blue, yellow and green If you can help I need to identify the wires (especially those that supply power), the power supply voltage, and whether it's an AC or DC supply. This is for hobby use / curiosity only. Thanks in advance.
