breff Posted April 4, 2007 Posted April 4, 2007 Can anyone tell me if the SMS module for the Texecom alarms can also be used to arm/disarm the alarm (It looks very similar to a keypad)Also whether you can shut off the siren remotely via a mobile phone for example in case the alarm keeps going off when you are away? It could be made to do it as it has 2 outputs, they could be connected to zones on the panel to arm/disarm. I wouldn't recommend it though. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
Guest anguscanplay Posted April 4, 2007 Posted April 4, 2007 Also whether you can shut off the siren remotely via a mobile phone for example in case the alarm keeps going off when you are away? if it could you really shouldnt use this feature think more on the lines of how do i get the system to do the same as a profesionally installed system and prevent the false alarms ie sitting sensors etc what im saying is dont over engineer the system take care with the mains angus
