Reflex Quad Pirs
F C E
Was Looking @ installing these Reflex Quad PIRs on a site wandered if you guys ad any experience of them
All comments in this post are my own views and do not necessarily reflect the views of my employer
Used to use reflex now use the prestige, both texecom.
They are a good detector just look a little dated now.
IMO the Reflex and Medusa are now typical electrician's choice detectors (ie cheap and cheerful). You can get alot better if you spend a couple of quid more. Take a look at the Rokonet Zodiac Quads if you want a cheap, good passive, or the IS215T from Honeywell (I believe they now do a Quad version too). The Optex RX40 is not a quad but still a good detector if you don't mind the relay noise.
Trade Member
We Use the Bosch and Texecom Prestige Series. Don't like the Reflex or Medusa Range
I've fitted hundreds of Reflex passives In Domestics, and had very few problems with them.
Good Cheap reliable detectors.
Errrrrrrrrrrr, I've heard they are good, but I think you meant Bass not me :oops:
sorry :yes: meant bass not you breff :oops:
There ok we use the blueline (which is new to us) and the TriTech Range they have an excellent catch performance. But we install the Texecom Prestige Range Which in my opineon is the best pir and dualtec we have used so far and less time consuming.
i agree honeywell would be my choice of detector
Why when the Honeywell IS 125 is in screw fix for 7 quid.
Thats why we stopped using them.
How many do you use a month?
Guest anguscanplay
its still a good detector though even if the public can buy it
