Guest jonlid Posted March 30, 2004 Posted March 30, 2004 Can anyone recommend a panel using iD sensors that combines intruder and fire detection for a domestic property. I was looking at the ade karizma but it seems that minerva & texecom are highly regarded. Can the minerva ts690id or the texecom premier 412 be used as a combined intruder/fire panel. Ideally I want a panel that I can monitor from a PC, the idea being to be able to check the status over the internet.
Guest dale Posted March 30, 2004 Posted March 30, 2004 The texecom premier doesnt support iD, but its an excellent system. You cant really monitor it over the internet even though it can be connected to a PC. The PC connection is really to program the panel or diagnose it. Although you can dial into the system from anywhere provided you have a compatible modem. Also would it be wise to have an alarm system controlled by a PC permanently connected to the Internet, if someone hacked into your PC then they could just shutdown your alarm system and rob your house! Dale
Guest dale Posted March 30, 2004 Posted March 30, 2004 I hate to say it but even with advanced firewalls it is still pretty easy (although time consuming) to hack a computer system. My office has an excellent firewall seen as we have a great deal of sensitive information on it (like flight software that we write for a large aircraft manufacturer) and it was only last month that someone managed to hack the internal webserver (and re-direct all the traffic to a porn site), as well as hack the MySQL server. So I wouldnt put my alarm system on the web!
Security Technician Posted March 31, 2004 Posted March 31, 2004 I used to use castle care-tech at my last company, you can get insite software and modem for remote access, but not sure about the net tho
Guest ade0202 Posted March 5, 2005 Posted March 5, 2005 Can anyone recommend a panel using iD sensors that combines intruder and fire detection for a domestic property. I was looking at the ade karizma but it seems that minerva & texecom are highly regarded. Can the minerva ts690id or the texecom premier 412 be used as a combined intruder/fire panel. Ideally I want a panel that I can monitor from a PC, the idea being to be able to check the status over the internet. 10222[/snapback] The menvier 690id will act as a fire alarm with 12v detectors through the id line it has 30 zones id and up to 8 extra zones through the keypads you can also get it with inbuilt digi modem for remote access with dail in facility and the software is available free to registered installers . if you need to accessit over the internet you would have to use a active computer on the internet and a printer/comms adapter
Nova-Security Posted March 5, 2005 Posted March 5, 2005 The texecom premier doesnt support iD, but its an excellent system. You cant really monitor it over the internet even though it can be connected to a PC. The PC connection is really to program the panel or diagnose it. Although you can dial into the system from anywhere provided you have a compatible modem. Also would it be wise to have an alarm system controlled by a PC permanently connected to the Internet, if someone hacked into your PC then they could just shutdown your alarm system and rob your house!Dale 10228[/snapback] In the premier range engineer manual in does show and supports ID, i think you need a aditional card for it ? www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
Paul P Posted March 5, 2005 Posted March 5, 2005 Why are we replying to posts made nearly a year ago? 42574[/snapback] Maybe we are board? Trade Member
Monteey Posted March 5, 2005 Posted March 5, 2005 The Texecom CAN be monitored over the internet now they've brought out an IP module, it CAN also support iD, with an iD expander. Get your facts straight Mark Hawks Ex BT Openreach Field Service Now Self employed telecom and data engineer www.mphtelecom.co.uk Also back doing sub contract work in the security industry. Retained firefighter Devon and Somerset Fire and Rescue
bellman Posted March 5, 2005 Posted March 5, 2005 The Texecom CAN be monitored over the internet now they've brought out an IP module, it CAN also support iD, with an iD expander. Get your facts straight 42578[/snapback] It can NOW, but couldn't at the time the post was made (check the date) Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
Monteey Posted March 5, 2005 Posted March 5, 2005 True the IP module wasnt out then but the iD expander was Mark Hawks Ex BT Openreach Field Service Now Self employed telecom and data engineer www.mphtelecom.co.uk Also back doing sub contract work in the security industry. Retained firefighter Devon and Somerset Fire and Rescue
