power series 632
Guest sledseller2
Guest sledseller2
is there any way to find the code or do i buy a new system?
Is it not the Power832?
You will need the engineer code(if is below ver 2.8), or the panel will need to be defaulted and re-programmed.
Have you tried calling the company that installed the system to see if they will come out and reset the master code for you?
jpaul
