Guest anguscanplay Posted April 9, 2007 Posted April 9, 2007 i have always wondered that how water can get into a duct when its supposedly sealed and the ends come in the building? condensation
luggsey Posted April 9, 2007 Posted April 9, 2007 condensation When it's stored outside, when it's transported, etc. ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum
Guest anguscanplay Posted April 9, 2007 Posted April 9, 2007 When it's stored outside, when it's transported, etc. heat generated by current in cable - air getting in each end warmer than earth loads of reasons for it sparky
Cubit Posted April 9, 2007 Posted April 9, 2007 heat generated by current in cable - air getting in each end warmer than earth loads of reasons for it sparky You've missed the obvious one - Buggerance factor It only gets in when you least need it.
Guest Sparky169 Posted April 9, 2007 Posted April 9, 2007 You've missed the obvious one - Buggerance factorIt only gets in when you least need it. now theres a very good answer and its true too. has anyone come accross collapsed ducts in their line of work before. i have and they are a right pain in the bum.
arfur mo Posted April 9, 2007 Posted April 9, 2007 now theres a very good answer and its true too.has anyone come accross collapsed ducts in their line of work before. i have and they are a right pain in the bum. no sparky169 me old china - thats piles lol regs alan If you think education is difficult, try being stupid!!!!
mjw Posted April 9, 2007 Posted April 9, 2007 no sparky169 me old china - thats piles lolregs alan now that is a right pain in the bum lol
DDIES Posted April 15, 2007 Posted April 15, 2007 good 8 core duct cable available from Newey&Eyre 7-2-8C PVC/twbc/PVC pvc braided steel Armour PVC then norm 8 core in side we have used lengths up to 500m but sure you can get longer if req not to expencive it's very expensive, it's about
arfur mo Posted April 15, 2007 Posted April 15, 2007 hi all, on long runs armoured my present simular problems to screened cable, as the pF value could be degrading to any multitplexed signal, so if room allows it i'll always go for toughest uPVC conjuit. also allows for an extra cables to be run at the same time or later due to oversight perhaps, in standard cable so pro rata a lot cheaper than a single armoured. regs alan If you think education is difficult, try being stupid!!!!
Monty Posted April 15, 2007 Posted April 15, 2007 You can we just did at a job for cctv cables and alarm cables app 25m 100m duct we should have had own duct but only draw wire in duct with swa and water main !!! so we drew 2 -20m marshal tuffflex flex conduit through and then pulled cctv in one and alarm in other bit of a job but easer than digging another duct in . www.AllanMoncrieffAlarms.com
