darrmick Posted April 8, 2007 Posted April 8, 2007 Can any one help with connection details between "Elmdene Prima Sounder" and a ADE G3 Panel this a repair/upgrade
camerabloke Posted April 8, 2007 Posted April 8, 2007 what do you want to know? Eucam Security Systems 0845 4630 746 www.eucam.co.uk
darrmick Posted April 9, 2007 Author Posted April 9, 2007 what do you want to know? I would like to know connections between ADE G3 panel and prima bell box i used to have install manual but have misplaced it in van somewhere.
Guest Sparky169 Posted April 9, 2007 Posted April 9, 2007 I would like to know connections between ADE G3 panel and prima bell box i used to have install manual but have misplaced it in van somewhere. take it your in the traade then
Guest anguscanplay Posted April 9, 2007 Posted April 9, 2007 Can any one help with connection details between "Elmdene Prima Sounder" and a ADE G3 Panel this a repair/upgrade http://www.thesecurityinstaller.co.uk/comm...c=10406&hl= take it thats a different one it is a thorny issue on the site at the moment connecting external sounders in the public forum but for reference they are all the same at a diy level 12v positive and negative trigger to make it sound trigger to flash the light return to panel to make it tampered thats all there is to it angus
darrmick Posted April 9, 2007 Author Posted April 9, 2007 http://www.thesecurityinstaller.co.uk/comm...c=10406&hl= take it thats a different oneit is a thorny issue on the site at the moment connecting external sounders in the public forum but for reference they are all the same at a diy level 12v positive and negative trigger to make it sound trigger to flash the light return to panel to make it tampered thats all there is to it angus Yes i am but i am a spark first but have some experience with fire and security systems i cam figure out that TM is tamp ret, str is strobe neg it is the 0v and neg trig which is which. Have to earn a crust somehow.
Guest anguscanplay Posted April 9, 2007 Posted April 9, 2007 Yes i am but i am a spark first but have some experience with fire and security systems i cam figure out that TM is tamp ret, str is strobe neg it is the 0v and neg trig which is which. Have to earn a crust somehow. hi darrmick please excuse my little joke its late on a sunday and im still at work as i said its a bit of a sore point on the forum at the moment this connecting external sounders as its a small step from telling how to connect to telling you how to disable one it might be better to use the messaging service and ask one of the members who helped you last time if they would do so again failing that a manual should be available from the wholsealer or the manf angus
Cubit Posted April 9, 2007 Posted April 9, 2007 I would like to know connections between ADE G3 panel and prima bell box i used to have install manual but have misplaced it in van somewhere. Woops, That must be some van, 10 months and you still can't find the manual
Guest anguscanplay Posted April 9, 2007 Posted April 9, 2007 Woops, That must be some van, 10 months and you still can't find the manual evil evil man
