Caretech Ct3000 Meridian
Stockholm
If anyone can help me by emailing these across i would be most greatful. A house that my client has purchased has these units and they need moving so will need to access the panels using engineer codes etc. Any ideas on *****************also useful.
Please read the forum rules, we do not give out engineering manuals or defaulting information.
You would be better to speak to the manufacturer.
This community will not divulge control panel defaulting instructions to standard members. Neither will this community provide Engineer/Installation manuals for any control panel or other security equipment."
All comments in this post are my own views and do not necessarily reflect the views of my employer
I can pretty much assure you that if you're not a Castle customer, the tech support won't tell you how to get into engineering menus.
And if you can't do that, on the 3000, the only means of changing the engineer codes is by changing the NVM.
That panel has to be 10-15 years old, and is no longer supported in any case. You can't even buy the prox tags for it anymore. You need to change the hardware, I think.
