Please can any body help me find the factory reset code for the Countess Alarm system. I have just moved into rented accomodation and the current alarm code is written on three adjacent walls around the main alarm control panel. I am a little concerened about this and would really appreciate any help.
Many thanks Martin(countess)
Perhaps the User manual will help, have a good read, there are instructions on how to change the User code.
Countess_User.pdf
hi Martin,
we do not give out 'defaulting' information for obvious security reasons, if after reading the manual you still have problems then best you ask the landlord to arrange for the code change for you.
it is his equipment, and many landlords will use any excuse to not return your deposit if an when you move on, so be wary before you alter anything always get prior permission.
regs
alan
  • Upvote 1
  • 2 months later...
Countess_User.pdf
Hi Magpye
My neighbour has a Countess Control Panel but no manual. I want to change his battery and reset all the codes including the Engineers code. Could you reattach the manual pdf file please. It seems the file is no longer there.
Thanks
Willowman
Guest anguscanplay
Hi Magpye
Thanks
Willowman
its not on service with an alarm company then ?
  • 12 years later...
As per the original 13 year old discussion we are unable to give out engineering manuals nor defaulting information.
I would strongly suggest having this now almost certainly 30 year old system replaced.
59 minutes ago, Jaco v d Merwe said:
Hope somebody might help me I bought a house with a Countess alarm system installed about 4 jrs back
Has your watch stopped...
...in 1993
