Guest millgate Posted April 1, 2004 Posted April 1, 2004 could someone please help I have a problem with our Alarm somebody hit the panic alarm and after we reset the system it has locked up and will not do anything. The Power light is on and the Attack light but the keypad is dead it doesnt matter what you press nothing happens I have downloaded the instruction manual but it doesnt cover faults ! Thanks Ollie
Guest dale Posted April 1, 2004 Posted April 1, 2004 Have you reset the panic button? Most panic buttons have either a key you need to turn or a button you need to press to reset. You should then be able to reset the alarm.
Service Engineer Posted April 1, 2004 Posted April 1, 2004 Dale`s correct, it does sound as though the panic button hasnt been reset. Find the key and reset the panic button, and your system should spring back to life. ........................................................ Dave Partridge (Romec Service Engineer)
Guest millgate Posted April 2, 2004 Posted April 2, 2004 thanks for your help I have reset the system now and it works perfectly I guess it is just a case of opening my bleeding eyes !!
