Need Help
Pat100
Can any one help
I had an alarm fitted 4 years ago. I have currently getting work done on the house and have been in contact with the original installer trying to find out if I can get it de activated while the work is going on. He says he can't find the manual. All I know about it is that the control panel has a C&K Securitech logo on plus the following code: CO23-203 Iss.1
And as you can guest the work has meant that the panel is now continually beeping with the lights flashing on and off the Mains, & TPR. I am really worried that my alarm is going to go off and I cannot stop it.
Can Anyone help Please,
Colin thanks for interest, but the MOD team dont need directions from you.
Hi Pat,
Any engineer that has experience in alarms should be able to deactivate the system for you. Try other installers i your area as this is a popular system for sparkys over here. Remember with the building works going on you may want the engineer to run cable at the same time to extend the system into your new build or if you have other areas in your house you want covered as i presume there will be floor boards up etc.
Thanks
Willie
Pat
I'm reasonably sure forum member Woosh covers your area. You may want to PM him?
Regards
Chris
Chris Teague (Sales & Operations Manager) Sightguard Intruder Division
Covering the Isle of Wight: - Design, Installation, Maintenance & Takeover of Intruder Alarms, Fire Alarms & Equipment, CCTV, Access Control, Nursecall. Keyholding Service, Guarding & Cash in Transit. SSAIB & NICEIC Registered Tel 01983 884000 / 884440
Any comments / opinions posted could be the voices in my head speaking, but they are my opinion only and do not represent those of my employer or Company
