zac47 Posted April 17, 2007 Posted April 17, 2007 hi i would like to know your views on the best way of fixing shock sensors (texecom impaq plus) to upvc window frames thanx
BASS Posted April 17, 2007 Posted April 17, 2007 Difficult one. Some windows we have done while the owner was having the new windows put in which is easy if you work with the window fitters to conceal the cable and bring it though the frame. in other cases we use the minature trunking pref the same colour as the frame and use the self stick trunking and you can't it's there time consuming I know but customer satisfaction is priority.
antinode Posted April 17, 2007 Posted April 17, 2007 Screws or nothing, else they will fall off. Trade Member
nikko Posted April 17, 2007 Posted April 17, 2007 Yep, gotta be screwed. Helps if you you mark it 1st then drill tiny pilot holes. Fishing the cables in can be done but you need experience really. I went up into the attic...I found a Stradavarius & a Picasso. Unfortunately..... Stradavarius couldn't paint, and Picasso made a shocking fiddle. My Facebook page...http://www.facebook.com/home.php#/profile.php?id=1279556853&ref=name
zac47 Posted April 17, 2007 Author Posted April 17, 2007 hi i would like to know your views on the best way of fixing shock sensors (texecom impaq plus) to upvc window frames thanx Thanx for the replies I like to use screws but have sometimes used a couple of spots of super glue which holds them on well, just fitting a new built bungalow and the customer was worried about is warranty on the windows using screws and I just wondered if anybody had come up with a better idea than the rubbish sticky pads to get round voiding warranty
antinode Posted April 17, 2007 Posted April 17, 2007 Thanx for the replies I like to use screws but have sometimes used a couple of spots of super glue which holds them on well, just fitting a new built bungalow and the customer was worried about is warranty on the windows using screws and I just wondered if anybody had come up with a better idea than the rubbish sticky pads to get round voiding warranty Trade Member
BASS Posted April 17, 2007 Posted April 17, 2007 No we screw the impaq to the window but the trunking we use either the stick pad or mostly pvc adheshive which bonds plastic to pvc which is great
Wooly-bobs Posted April 18, 2007 Posted April 18, 2007 Would of thought the use of sticky pads would act as a shock absorber on vipers
Adi Posted April 18, 2007 Posted April 18, 2007 Exactly what i thought mate. I really can't be ar**** with it anymore.
