Best Intruder Panel?
Been fitting coopers 9853 good panel flexable with W/F add on's but have fitted the M800 and M600 found to have much more flexability/options and now the W/F op even better and by far a better log.
www.AllanMoncrieffAlarms.com
  Paul P said:
Can you test the Redcare channels without beating the user code out of the customer yet?
Hello,
Menvier Mseries & Scantronic 95EN have the ability to use 'false setting'
This is effect works backwards
You choose what circuits to arm and also if you want the outputs (bell & comms) to follow the setting.
Very useful can be done from engineers menu and the system is unset after with 1 simple key push that is displayed on the remote.
Aritech ATS !!
Trade Member
a big big Gardtec fan, very simular program menu for clients and engineer through the range over the years (above the G300/350 which i don't use).
shear reliability has to be the big winning point, i find i change out other makes panels due system faults several times a year, these tend to be PSU faults after restrt from flat, only ever changed 2 Gardtec's due to same fault in appx 20 years using them.
has t be said the radio detection kit is also very good
regs
alan
  • 2 weeks later...
Texecom so far!
i havent seen a keypad as stylish as there crome or brass flush mounted anywhere!
if you have a laptop then programming is a piece of piss! also
but in saying that i havent experienced Galaxy yet....
