Guest Posted April 22, 2007 Posted April 22, 2007 DM do a wiper unit for their 506 housing but then you need to work out how you are going to switch the old girl on and off ?? Perhaps the beterware spray may be a good place to start. Dave
arfur mo Posted April 22, 2007 Author Posted April 22, 2007 DM do a wiper unit for their 506 housing but then you need to work out how you are going to switch the old girl on and off ?? Perhaps the beterware spray may be a good place to start. Dave hi Dave, i'd simply fit a timer to run once every hour or so just for a few seconds, it don't need to touch the screen, just destroy the webs. regs alan If you think education is difficult, try being stupid!!!!
arfur mo Posted April 22, 2007 Author Posted April 22, 2007 computar make a wiper unit and can have wash intergrated into the setup too not sure what housings this would fit onto though http://www.electroflowcontrols.com/pdf/CCT...557%20Wiper.pdf this may help thanks sparky169, i have emailed then for details regs alan If you think education is difficult, try being stupid!!!!
arfur mo Posted April 22, 2007 Author Posted April 22, 2007 Are they making webs across the housing with no IR's? does this housing have a heater?.Try replacing with vandal domes Hi AS, these positions are very exposed, i did consider the vr dome route, but feared it will get another problem with rain running down the outside of the dome in wet weather. if fit a shroud above it, i might just land me back at square one. there is 2 ptz domes on the same site, and even they have the webs on the domes, don't affect them so bad but enough to be a pia all the same. regs alan If you think education is difficult, try being stupid!!!!
Guest anguscanplay Posted April 23, 2007 Posted April 23, 2007 challenge them to a game and if they lose they have to find somewhere else to hide or tie one to each leg so they cant climb http://www.spidergone.co.uk/
Phil Sumner Posted April 24, 2007 Posted April 24, 2007 Hi, as Dave said DM do wipers for a number of the housings in the range. If it's a Dennard camera housing let me know and I'll dig out details. -- psumner@dmicros.com Manufacturer
arfur mo Posted April 24, 2007 Author Posted April 24, 2007 or tie one to each leg so they cant climbhttp://www.spidergone.co.uk/ Angus, sent off for a can today, most advertise they will only last about 3 - 4 weeks internal usage. this is the first to say about 8 months @ If you think education is difficult, try being stupid!!!!
arfur mo Posted April 24, 2007 Author Posted April 24, 2007 Hi, as Dave said DM do wipers for a number of the housings in the range. If it's a Dennard camera housing let me know and I'll dig out details. hi phill, i have sourced a housing with a wiper attached, thanks for you help it is appreciated. as it's to deal with the webs rather than clean, i'm concidering replacing the wiper blade with one of the ruling halfes hair roller's, as they scare the pickle out me regs alan If you think education is difficult, try being stupid!!!!
Guest anguscanplay Posted April 24, 2007 Posted April 24, 2007 we used to be able to get like a marker pen of killer but i think brussels banned it as too many chavs were sucking on them let us know if it works otherwise it was your choice and im not refunding the tenner
arfur mo Posted April 24, 2007 Author Posted April 24, 2007 we used to be able to get like a marker pen of killer but i think brussels banned it as too many chavs were sucking on them let us know if it works otherwise it was your choice and im not refunding the tenner i'll settle for a pint of you at IFSEC then i'll post what happens, if it is effective might rig up to a pole like a smoke head tester to save getting up to the camera's. regs alan If you think education is difficult, try being stupid!!!!
