c4rtm4n Posted April 21, 2007 Posted April 21, 2007 Hi I've been doing a spot of DIY this afternoon and have accidentally drilled through a wire that leads to the zone that covers my garage door, shredding 5 of the cores but leaving one intact. I have a Gardtec 360 that's about 10 years old & it's showing a 't' as it obviously thinks that it's been tampered with. When I try & set the alarm & remove the relevant zone it again comes up with the 't', the internal buzzer sounds & it won't set. Is there any way that I can perform some kind of reset so that I can part set my system until I get an engineer out to replace the wire (there's not enough give to pull the wire through & reconnect all of the cores myself. I don't know the engineer code (it's not the default) but obviously know the master code. Any help would be appreciated as I really don't want to leave the house unprotected & given that I'm doing more work on the wall around where the wires go I'd like to get it finished before having someone come out in a couple of weeks time - I'd hate for the same thing to happen again. Thanks Steve
camerabloke Posted April 21, 2007 Posted April 21, 2007 hi cartman, you more than likely have drilled through a tamper circuit and will not clear down untill the wire has been fixed, therfore i recomend an engineer to pay you a visit Eucam Security Systems 0845 4630 746 www.eucam.co.uk
c4rtm4n Posted April 21, 2007 Author Posted April 21, 2007 Thanks camerabloke The log on the alarm shows zone 7 which is the garage - could this still mean that it's the tamper circuit rather than the zone itself? Is there any way that I can remove zone 7 by say disconnecting the wires to it in the control box as I'd really just prefer to patch things up temporarily until I'm finished my work as I'm running a whole load of cables inside the wall where the keypad & internal sounder are & the risk of this happening again is 'above average' I guess. Nice avatar ! Steve
camerabloke Posted April 21, 2007 Posted April 21, 2007 there is but you will need an engineer code to disable the zone im afraid. Eucam Security Systems 0845 4630 746 www.eucam.co.uk
c4rtm4n Posted April 21, 2007 Author Posted April 21, 2007 Can I default the system in a similar way to that suggested in this topic Link so that I can do this as the system is no use to man nor beast at the moment? Steve
kka Posted April 21, 2007 Posted April 21, 2007 what area of the north east are you Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
c4rtm4n Posted April 22, 2007 Author Posted April 22, 2007 Sorted! - I had to make a mess of my wall as the wires were behind dabs of plaster but I've replaced the wire & everything is now fine! Thanks Steve
