luggsey Posted April 27, 2007 Posted April 27, 2007 2foot im your friend angus It's 500mm for cables not in ducting or 19.685 inches and I will be checking! I'm a bad boy cause I only got to 18". Angus I love it when you get angry! ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum
arfur mo Posted April 28, 2007 Posted April 28, 2007 I also said;"If you want a really cheap job not to standard but will work, buy a roll of 20mm copex flexible conduit and pull an alarm cable into it before burrying it >18" under ground. Copex is waterproof and as long as both ends are inside it should be ok, don't forget to use tampered joint boxes inside if you have too!" Armoured is the only cable suitable for direct burial so not overkill in any respect....... Edited typo. Copex is not imo tough enough for direct burial, it is a flexible tube to offer at best neatness rather than a mechanical protection solution, a spade or fork would easily slice straight through it. i also where did i say direct burial of cable? i suggested tubing specifically designed for the purpose and cable within it. armoured is expensive and requires some skill to terminate properly and safely. i'd prefer to take non-combatants along safer and easier route. regs alan If you think education is difficult, try being stupid!!!!
luggsey Posted April 28, 2007 Posted April 28, 2007 Copex is not imo tough enough for direct burial, it is a flexible tube to offer at best neatness rather than a mechanical protection solution, a spade or fork would easily slice straight through it.i also where did i say direct burial of cable? i suggested tubing specifically designed for the purpose and cable within it. armoured is expensive and requires some skill to terminate properly and safely. i'd prefer to take non-combatants along safer and easier route. regs alan Copex can be metal as well...... I suggested armoured direct burried was not overkill as you suggested it was..... ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum
arfur mo Posted April 28, 2007 Posted April 28, 2007 Copex can be metal as well......I suggested armoured direct burried was not overkill as you suggested it was..... lol, obvioulsy it would depend on the distance involved, but the cost of 50mtr's armoured to go say 10-15 mtr's, glands, metal boxes and all the faffing around against the plastic HD conduit (for the PC on here) /polypipe? it's not a commercial site or risk area like petrol station or garden centre, thats why i say it's overkill and i just know which way i'd go in a private dwelling regs alan If you think education is difficult, try being stupid!!!!
luggsey Posted April 28, 2007 Posted April 28, 2007 lol,obvioulsy it would depend on the distance involved, but the cost of 50mtr's armoured to go say 10-15 mtr's, glands, metal boxes and all the faffing around against the plastic HD conduit (for the PC on here) /polypipe? it's not a commercial site or risk area like petrol station or garden centre, thats why i say it's overkill and i just know which way i'd go in a private dwelling regs alan Most people think you have to use glands with armour, it's ok for FELV to be stuffed in a 20mm hole if that looks ok without glands, just strip the armour back and tape up. My wholesaler(s) sell armoured to any cut length you want so it would be a toss up for me between armour, easy to install, or flaf about with bits of pipe and draw wires, armour every time for me! ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum
