scootz Posted April 30, 2007 Posted April 30, 2007 Hello Everyone, I have the above system which is approx 9yrs old and in the last week or so the external siren has been going off on its own with no tamper/attack/power problems being highlighted at the control panel. The control panel seems perfectly normal and entering the code only sets the system and the siren stays on for twenty minutes then switches off. This has happened twice now once in the middle of the night! I did not install the system, but the guy who did unfortunately is not available to contact anymore, can someone offer any advice? I was thinking the battery backup in the siren may be the problem as it has never been changed but that is a stab in the dark! Thanks in advance. Scootz
kka Posted April 30, 2007 Posted April 30, 2007 a service will discover the extent of the problem. Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
Guest anguscanplay Posted April 30, 2007 Posted April 30, 2007 hi scootz im assuming you dont have a maintainance contract if the original installer is no longer contactable and if the system hasnt been checked since install then getting the system serviced is the place to start its always my advise to get this checked by a competant alarm engineer as security systems are designed not to be end user servicable ring two or three local firms - explain the problem and they should be able to give you an estimate of cost and its a good idea to take out a service contract for the following year too dont delay too long as its not a problem thats likely to cure itself angus
arfur mo Posted April 30, 2007 Posted April 30, 2007 Hello Everyone,I have the above system which is approx 9yrs old and in the last week or so the external siren has been going off on its own with no tamper/attack/power problems being highlighted at the control panel. The control panel seems perfectly normal and entering the code only sets the system and the siren stays on for twenty minutes then switches off. This has happened twice now once in the middle of the night! I did not install the system, but the guy who did unfortunately is not available to contact anymore, can someone offer any advice? I was thinking the battery backup in the siren may be the problem as it has never been changed but that is a stab in the dark! Thanks in advance. Scootz hi scootz and welcome, most likely, if the system has not been checked then the battery has failed, a small fluctuation in the mains supply can cause your problem, but it is not the only cause. well worth getting in a competant engineer to check out your system properly, and advise you of the many items and advances that have occured over time or modifications to suit your current needs more closely. regs alan If you think education is difficult, try being stupid!!!!
scootz Posted April 30, 2007 Author Posted April 30, 2007 hi scootz and welcome,most likely, if the system has not been checked then the battery has failed, a small fluctuation in the mains supply can cause your problem, but it is not the only cause. well worth getting in a competant engineer to check out your system properly, and advise you of the many items and advances that have occured over time or modifications to suit your current needs more closely. regs alan Thanks alan, waiting on engineer calling back, scootz
arfur mo Posted April 30, 2007 Posted April 30, 2007 Thanks alan, waiting on engineer calling back, scootz your vey welcome scootz i hope its not to expensive. regs alan If you think education is difficult, try being stupid!!!!
