sd6446 Posted May 8, 2007 Posted May 8, 2007 I am currently installing a Eurosec CPX alarm system, with 2 RKPs, and 2 G-Tag proximity detectors - one internal, one external. So far everything seems to be working ok, until I tried connecting one of the G-Tag prox detectors to one of the RKPs. This results in the backlight on both RKPs flickering at the same rate as that of the blue LED on the prox detector. I have tried both internal and external detectors and they both produce the same annoying effect. Has anyone else seen this before? Any ideas would be very much appreciated.
Wooly-bobs Posted May 8, 2007 Posted May 8, 2007 Take the supply from the Aux instead of the RKP 12v. Should help the problem.
sd6446 Posted May 8, 2007 Author Posted May 8, 2007 Take the supply from the Aux instead of the RKP 12v. Should help the problem. Many thanks for the quick reply Chris - it's a good suggestion. My only concern is that the G-Tag prox. readers connect to '0V', 'Set', 'Ant1' and 'Ant2' on the RKP, and not to the '12v'. However, do you think 'Set' is effectively the 12v supply, so could be substituted with the AUX from the main unit instead?
arfur mo Posted May 8, 2007 Posted May 8, 2007 Many thanks for the quick reply Chris - it's a good suggestion. My only concern is that the G-Tag prox. readers connect to '0V', 'Set', 'Ant1' and 'Ant2' on the RKP, and not to the '12v'. However, do you think 'Set' is effectively the 12v supply, so could be substituted with the AUX from the main unit instead? hi sd6446 it's not the g-tag reader thats flickeing but the keypad so use the 'fix' suggested, as it is the 'official' one direct from Gardtec Tech Help. regs alan If you think education is difficult, try being stupid!!!!
Guest anguscanplay Posted May 8, 2007 Posted May 8, 2007 Take the supply from the Aux instead of the RKP 12v. Should help the problem. hi sd6446it's not the g-tag reader thats flickeing but the keypad so use the 'fix' suggested, as it is the 'official' one direct from Gardtec Tech Help. regs alan good advise - just to clarify for the poster use the aux terminals at the panel to power the keypad voltage instead of the keypad terminals - connect the g-tag as per the manual
arfur mo Posted May 8, 2007 Posted May 8, 2007 good advise - just to clarify for the poster use the aux terminals at the panel to power the keypad voltage instead of the keypad terminals - connect the g-tag as per the manual just to be pedantic then, move only the keypad + ve to the aux + ve now where did i put my anorac? regs alan If you think education is difficult, try being stupid!!!!
Guest anguscanplay Posted May 8, 2007 Posted May 8, 2007 just to be pedantic then, move only the keypad + ve to the aux + venow where did i put my anorac? regs alan calm down dear i wasnt having a dig for a change - the o/p had read it wrong same as i did first time so i clarified it nurse time for arfurs nap
sd6446 Posted May 8, 2007 Author Posted May 8, 2007 calm down dear i wasnt having a dig for a change - the o/p had read it wrong same as i did first time so i clarified itnurse time for arfurs nap Hi. Thanks very much for clarifying this, as I had misinterpreted the original response. Sadly, I've just tried the suggestion, and wired the 12v RKP to the AUX 12v, and although this has improved the flickering, it is still very much noticeable. Also, I emailed Gardtec this afternoon, who responded very promptly with a suggestion to change the RKP 250mA fuse to a 1A - interesting idea - which also had a slight improvement (presumably due to a lower resistance?). Any other suggestions would be most welcome,
Guest anguscanplay Posted May 8, 2007 Posted May 8, 2007 Hi. Thanks very much for clarifying this, as I had misinterpreted the original response. Sadly, I've just tried the suggestion, and wired the 12v RKP to the AUX 12v, and although this has improved the flickering, it is still very much noticeable. Also, I emailed Gardtec this afternoon, who responded very promptly with a suggestion to change the RKP 250mA fuse to a 1A - interesting idea - which also had a slight improvement (presumably due to a lower resistance?). Any other suggestions would be most welcome, there is a known bug with the keypads at the moment but i cant put my hand on the sheet they sent out with the fix - mail them again and ask if the two could be related - ask them about corrupt displays angus
Alarm Protection Posted May 8, 2007 Posted May 8, 2007 there is a known bug with the keypads at the moment but i cant put my hand on the sheet they sent out with the fix - mail them again and ask if the two could be related - ask them about corrupt displaysangus We have had problems with the 595 panel doing this if keypad runs are over 90mtrs. I would contact your supplier for more details but when i get back n the office tomm i will look up what the problem is. !
