Commercial Alarm Query
Hello all, i wondered if any of you chaps could recommend a reliable grade 2> alarm system for a small sports hall? only one entrance covered by a metal roller shutter, no windows in the full building, needs to have fire and smoke alarm inputs, i do need the system to be monitored, back-up battery, bellbox, internal sounder etc. And one main keypad just near the front door as a means of dis/arming.
Many thanks
Carl
www.Home-IQ.co.uk
Texecom premier 48, grade 3, full choice of comms options, & very reliable.
Guest anguscanplay
Many thanks
Carl
www.Home-IQ.co.uk
what kind of monitoring do you require - i assume you mean full police response
Yes Angus, monitored using //.Large National Installer.//, then to keyholders and Police.
cheers
Guest anguscanplay
cheers
but youre fitting it
Guest anguscanplay
yes, in the next 2 weeks
help you more later - but who is applying for the URN and how are you planning to generate a confirmed signal?
Many thanks
Carl
www.Home-IQ.co.uk
I would recommend a G3 Galaxy system (I know you want Grage 2 but its easier to upgrade to Grade 3 at another day) You can also have a max reader fitted to set and unset from utside to prevent false activations and I would also recommend a GSM Redcare for you monitoring
good question m8
sw
the local council are sorting the URN, and i am installing a tritech sensor to send the confirmed signal, i generally fit 'comfort type' alarms more to do with the home automation market, so this commercial job is a bit different for me to be honest!! so any help is appreciated and will be used in the strictest confidence.
regards
Carl Nycz.
www.Home-IQ.co.uk
Guest anguscanplay
regards
Carl Nycz.
www.Home-IQ.co.uk
local council sorting urn? - something your not telling us and who did the risk assesment?
