Coiled Cable
Rich
I am urgently trying to find a supplier of the coiled cable for telescopic masts as in the picture, does anyone know where I can get this from?
cheers
Is that cable or is it actually a semi-rigid coiled plastic tube with the cable fed through it?
I have no idea but the tube is probably a better option, know where I can get that from ?
Would the stuff that connects artic trailers to the cab units do the job?
In which case you want a commercial vehicle supplies place.
cheers
You can get this stuff but it is expensive! I have a pump up mast and was going to get some but the cost put me off!
SMC masts PDF
My Amateur Radio Forum
Thanks for the input so far.
Also, forgot to mention we need 25 cores !
Will give those companies a call on monday, thanks.
