nab1957 Posted May 18, 2007 Posted May 18, 2007 Hi there Can anyone help with this problem, the battery on my Veritas 8 control panel has gone down, so I replaced with a new one. Think I have done everything right, but now after setting the alarm when I go out, on re-entering when I open a door contact the alarm goes off immediately, I have lost the 30 second entry time to unset the alarm. I have to unset as normal but the zone light for the door is on, and I then have to reset as well to get this off. Any sugeestions. Regards Neil
camerabloke Posted May 18, 2007 Posted May 18, 2007 it sounds like it has defaulted to factory settings and as such will require an engineer to repair Eucam Security Systems 0845 4630 746 www.eucam.co.uk
nab1957 Posted May 18, 2007 Author Posted May 18, 2007 it sounds like it has defaulted to factory settings and as such will require an engineer to repair Understand, but surely the alarm would not set itself with my personal code if it had defaulted to factory settings
breff Posted May 18, 2007 Posted May 18, 2007 And Im assuming that the front door is zone 1? the default for zone 1 is entry/exit. The panel could probably benefit from a cold start. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
TheKey Posted May 20, 2007 Posted May 20, 2007 Hi thereCan anyone help with this problem, the battery on my Veritas 8 control panel has gone down, so I replaced with a new one. Think I have done everything right, but now after setting the alarm when I go out, on re-entering when I open a door contact the alarm goes off immediately, I have lost the 30 second entry time to unset the alarm. I have to unset as normal but the zone light for the door is on, and I then have to reset as well to get this off. Any sugeestions. Regards Neil Did you change the battery yourself? If so have you checked that you havent caught any wires and pulled one loose or even damaged it slightly? sw
