Guest hammersmith Posted April 6, 2004 Share Posted April 6, 2004 We have an Optima 2 Plus alarm in our house. This morning, the decorator knocked the cover off the sensor in the lounge. Now on the alarm panel, the tamper light is lit as well as the light for zone 2 (the lounge). We have entered our PIN number and pressed reset but the tamper light will not go out. Any advice gratefully received to get our system back working properly !! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/1907-optima-2-plus-tamper/ Share on other sites More sharing options...
Guest dale Posted April 6, 2004 Share Posted April 6, 2004 Make sure the cover is on the sensor properly, then reset. It will not reset until all the tampers have been cleared. The system may require an engineer reset (if programmed), this would invlolve the engineer coming to reset the system for you. D Link to comment https://www.thesecurityinstaller.co.uk/community/topic/1907-optima-2-plus-tamper/#findComment-10555 Share on other sites More sharing options...
Guest hammersmith Posted April 6, 2004 Share Posted April 6, 2004 Thanks for the advice 'D', just checked the cover was back on the sensor (it was not on properly) and the alarm has now reset OK !! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/1907-optima-2-plus-tamper/#findComment-10560 Share on other sites More sharing options...
Guest dale Posted April 6, 2004 Share Posted April 6, 2004 Glad we could help. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/1907-optima-2-plus-tamper/#findComment-10564 Share on other sites More sharing options...
