Guest stejrobbo Posted April 8, 2004 Posted April 8, 2004 please help im urgently in need of a user manual for a optima xm alarm system i have a false alarm situation after 30 minutes and need it sorting
ian.cant Posted April 8, 2004 Posted April 8, 2004 OPTIMA XM USER MANUAL CUSTOMER PROGRAMMING TO BEGIN From day DAY led showing Press PROG all led
morph Posted April 8, 2004 Posted April 8, 2004 You can get an Optima Manual hereADE Website the basic user functions are the same, email their customer services for your specific manual. Colin.
Guest stejrobbo Posted April 8, 2004 Posted April 8, 2004 many thanks guys......i checked the last alarm situation and its showing the pir in the kitchen ........how do i check this pir is working as it should before replacing is there a simple test........thanks again steve
ian.cant Posted April 8, 2004 Posted April 8, 2004 Your pretty much asking "How long is a piece of string". Generally PIR's rarely fail, if they false alarm its because something in the local enviroment causes the false alarm. Has anything changed in the area recently? probably not! Check inside the pir for insects or spiders, more than likely the cause. Then you should maybe consider replacement. Failing that then then i suggest you contact your local company or give your location and maybe some of the guys here can help you out!
