Acron (Scantronic) Avenger VI Panel Help Needed
Guest starion
Guest starion
I am a security dealer who needs help programming an Acron (Scantronic) AV6000 Avenger VI alarm system.
The system is powered up, we have performed the jumper reset for a forgotten master code, which puts us into the programming. However, we cannot figure out how to change the master code to one of our choosing. Everything we have tried does not seem to work.
We have the installation manual, but it seems to be somewhat vague on some items. Any of you circa 1987-1990 alarm guys out there that can help?
Are you using the DIGI-Keypad..? and if you are have you told it what panel its conected too..?
For use with the AV6000/8000 panel where the processor is marked 3113 then the keypad should be configured by the following sequence....
ENTER - MODE- 9092 - ENTER
Guest starion
Yes, we are using the DIGI keypad, and yes we have set the product code (it is a 3135) sequence was:
Enter Mode 9091 Enter
No luck.
