daywalker Posted May 24, 2007 Posted May 24, 2007 Ive just found hidden away two boxed up Adpro units plus some transmitters, does anyone know if they are still used in the trade, if they have any value or are they only good as scrap?
Joe Harris Posted May 24, 2007 Posted May 24, 2007 Adpro aka 'Vision Fire & Security' aka 'Xtralis' will still support the product until 2011 however mostly people have moved away from fastscan units such as the one you described. http://www.vision-fs.com/opencms/opencms/s..._adpro_eol.html Mostly supported units now are fasttrace. Check the signalling methods available on the unit also considering that ISDN is being phased out and PSTN will be supported on only a limited basis for cctv in the future by most remote monitoring providers.
justin Posted August 26, 2007 Posted August 26, 2007 Adpro aka 'Vision Fire & Security' aka 'Xtralis' will still support the product until 2011 however mostly people have moved away from fastscan units such as the one you described.http://www.vision-fs.com/opencms/opencms/s..._adpro_eol.html Mostly supported units now are fasttrace. Check the signalling methods available on the unit also considering that ISDN is being phased out and PSTN will be supported on only a limited basis for cctv in the future by most remote monitoring providers. Hi can i just check something with you as you seem to know about adpro stuff. On the fastrace units connected via ethernet is it just one port i need to forward in the router port 15000 as it comes. It refers to this as a base port number, just checking, i don't think it does but will it use a range of ports. Many Thanks.
camerabloke Posted August 26, 2007 Posted August 26, 2007 just one port needed Eucam Security Systems 0845 4630 746 www.eucam.co.uk
