yellowcar Posted May 24, 2007 Posted May 24, 2007 Hi, The builders have finally finished rendering and I thought I'd put our Telecom Security (dummy) box back up. I have the box, screw and the cap, but I can't find the bracket anywhere! Is the L-shaped bracket a standard fit, the likes of which I may find at the DIY stores? Thanks █ www.wiinetwork.co.uk - Nintendo Wii Worldwide User Map
arfur mo Posted May 24, 2007 Posted May 24, 2007 Hi,The builders have finally finished rendering and I thought I'd put our Telecom Security (dummy) box back up. I have the box, screw and the cap, but I can't find the bracket anywhere! Is the L-shaped bracket a standard fit, the likes of which I may find at the DIY stores? Thanks i don't know about this bracket usually a decoy has a back plate or only a mild steel strip bent to suit, just don't ask for the engineers code or manual for it lol regs alan If you think education is difficult, try being stupid!!!!
sparky3366 Posted May 24, 2007 Posted May 24, 2007 If all else fails, a very long screw(!) through the existing hole into the brickwork will do... If at first you don't succeed...don't try skydiving!
magpye Posted May 24, 2007 Posted May 24, 2007 If all else fails, a very long screw(!) through the existing hole into the brickwork will do... Well, that won't work will it, the lid to bracket fixing is at the bottom. Someone told me I was ignorant and apathetic, I don't know what that means, nor do I care.
sparky3366 Posted May 24, 2007 Posted May 24, 2007 thought it had a central hole on the front... oops If at first you don't succeed...don't try skydiving!
breff Posted May 25, 2007 Posted May 25, 2007 Im sure it soon could have!!! The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
Guest Sparky169 Posted May 25, 2007 Posted May 25, 2007 try any diy stores in the bracket department a normal l shaped brack should do id have thought take a look at the drawing supplied. bellbox_mountiong.bmp
camerabloke Posted May 26, 2007 Posted May 26, 2007 hi guyssome posts are hidden after complaint from member, 2nd opinion needed from another mod (see it is a democracy )regs arfur quote and post deleted Eucam Security Systems 0845 4630 746 www.eucam.co.uk
Cubit Posted May 26, 2007 Posted May 26, 2007 try any diy stores in the bracket department a normal l shaped brack should do id have thought take a look at the drawing supplied. I see this piece of advice is yet again potentially dangerous. Assumptions been made that the op is capable/competent/able of carrying out said procedure with due regard to regulations. I refer of course to the oft ignored Working at Heights Regulations. For those who may consider this unimportant, may i refer you to; HSE. The Work at Height Regulations (2005) as amended, a brief guide. para 2 As is often quoted. Ignorance is no excuse.
Chorlton Posted May 26, 2007 Posted May 26, 2007 I see this piece of advice is yet again potentially dangerous.Assumptions been made that the op is capable/competent/able of carrying out said procedure with due regard to regulations. I refer of course to the oft ignored Working at Heights Regulations. For those who may consider this unimportant, may i refer you to; HSE. The Work at Height Regulations (2005) as amended, a brief guide. para 2 As is often quoted. Ignorance is no excuse. Good point Cubit. In addition we don't know the OP's medical history. He will experiance acute vertigo if he suffers from a middle ear infection, middle ear inflammation, M
