arfur mo Posted May 29, 2007 Posted May 29, 2007 good one did you know i have only ever had two electric shocks me too they were both bills regs alan If you think education is difficult, try being stupid!!!!
camerabloke Posted May 29, 2007 Posted May 29, 2007 sounds like a loose connection in the spur or into the con unit Eucam Security Systems 0845 4630 746 www.eucam.co.uk
sparkydude Posted June 2, 2007 Posted June 2, 2007 sounds like a loose connection in the spur or into the con unit He has not got a spur, it is connected directly to the consumer unit (not Recommended) SO it can only be a loose connection in the panel or the fuse box. Nick
amateurandy Posted June 2, 2007 Posted June 2, 2007 He has not got a spur, it is connected directly to the consumer unit (not Recommended) SO it can only be a loose connection in the panel or the fuse box.Nick Or a cable fault of course.....
sparkydude Posted June 2, 2007 Posted June 2, 2007 Unlikeley to be a cable fault in the 6 inches of cable between the panel and the consumer unit, and as he has stated it has no spur it is fed from the consumer unit 6 inches away i think it is unlikeley there is a spur under the floor above. Has to be a broken core in the cable between a and b in my book, probably snapped off the fuse terminal inside the consumer unit due to screw being over tightened. Nick
amateurandy Posted June 2, 2007 Posted June 2, 2007 Unlikeley to be a cable fault in the 6 inches of cable between the panel and the consumer unit, and as he has stated it has no spur it is fed from the consumer unit 6 inches away i think it is unlikeley there is a spur under the floor above. Has to be a broken core in the cable between a and b in my book, probably snapped off the fuse terminal inside the consumer unit due to screw being over tightened.Nick I think I'd call that a cable fault.............. (broken core caused by over-tight screw)
barooga Posted June 2, 2007 Posted June 2, 2007 but im thinking that it could be a hidden spur under the floor maybe have seen this done before. Why?? Already stated, it is connected direct to Con unit so no hidden spurs. If the op is competent with electrics this should be easy to check, but the fact that the question was asked would suggest otherwise. If not competent i really would suggest getting somene in who is. Not worth the risk whee safety is concerned. Growing old is mandatory, growing up is optional
Guest anguscanplay Posted June 2, 2007 Posted June 2, 2007 i imagine if he hasnt mended it yet the sab might have started lol
camerabloke Posted June 3, 2007 Posted June 3, 2007 no offence, but if the op was that confident with electrics he wouldnt have needed to ask the question in the first place Eucam Security Systems 0845 4630 746 www.eucam.co.uk
Guest anguscanplay Posted June 3, 2007 Posted June 3, 2007 QFA (quoted for arugment sorry agreement might be the best one yet this year " im not a diy`er im a computer network engineer , electrical engineer , shop owner , lift engineer" wonder what trade doesnt make you competant to work with electricity/security systems grr lol
