Guest Guest_John Posted April 13, 2004 Posted April 13, 2004 I'm replacing an Optima XM with a new G3 panel. Are there any reasons why I should not fit wire links to un-used zones, rather than setting them all to "disabled". - I just dont trust micro-processors!
breff Posted April 13, 2004 Posted April 13, 2004 No problem whatsoever with linking out unused zones, lots of panels come with links fitted and you just remove the zones youre using. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
