SHB1 Posted May 31, 2007 Posted May 31, 2007 Hello and help! Can anyone tell me why the sensors on my Accenta6 have just stopped working? There is no red light on them to show they are picking up any motion - but they were fine yesterday????
sparky3366 Posted May 31, 2007 Posted May 31, 2007 Hello and help!Can anyone tell me why the sensors on my Accenta6 have just stopped working? There is no red light on them to show they are picking up any motion - but they were fine yesterday???? Fuse blown inside the panel... If at first you don't succeed...don't try skydiving!
SHB1 Posted May 31, 2007 Author Posted May 31, 2007 Hello and help!Can anyone tell me why the sensors on my Accenta6 have just stopped working? There is no red light on them to show they are picking up any motion - but they were fine yesterday???? Thanks. Is there a fuse specifically for the sensor then? If so do you know which one? I understand from reading a manual on line that there are three? I am a girl so go easy on me!!!
amateurandy Posted May 31, 2007 Posted May 31, 2007 Thanks. Is there a fuse specifically for the sensor then? If so do you know which one? I understand from reading a manual on line that there are three? I am a girl so go easy on me!!! Fuses blow for a reason, so you really will need an engineer to find out why and sort it out. And of course opening up the panel exposes mains voltage - so don't do that unless you're competent to do so.
morph Posted May 31, 2007 Posted May 31, 2007 When was the system last serviced? I would reccomend getting an engineer in to check the system over cost should be about
