Is Is Possible? Aritech Panel
tt12
Hi all
Update:: instead of reverting to galaxy we've kept our aritech panel that now works after being replaced!! Intial security have finally sorted it! But Ive got a question, at the moment Ive got 3 different user codes set up to go to ARM menu when setting, Ive got a 4th code that goes straight to normal set, is it possible to give this 4th code attributes to go to arm menu or is there only a maximum number of codes that can go to menus?
Thanks in advance
TT
Retail security mgr
You can set any code to do anything, ie just arm, unset, walk test, chime etc, its something the engineer will have to setup depending on the panel weather its a old CD range or new ATS, unless you have a master user code which lets you asign atributes to codes, have a look in your user manual if you have a master user code for the system.
www.nova-security.co.uk
www.nsiapproved.co.uk
doesnt matter about remote reset, its more to do with the fact that i want the menus avaliable because it goes to fast to normal set otherwise and minimises the time to leave the building.... u have to literally run! panel quite far away from exit!
