bellboi Posted June 4, 2007 Posted June 4, 2007 Hi All, Firstly what a great site. I'm about to install a Texecom Prem 48 in a new property and wanted to check the power requirements before installing eveything and finding that I should have another PSU to help provide the power, I know the Prem48 has a 1.5amp PSU but I would rather do the job right and have room for expansion than cause a blown fuse and tamper alarm at 2.35am! Although I'm a DIY'er I am ex store operations for a large well known high street retailer and have been using/programming there Alarm systems since the Munford & White days of CPA6's and Modern panels (anyone guessed who I used to work for ? ) I'm about to install a Prem 48 with the following, however something tells me I should install a separate larger PSU (2amp) to run the detection devices off: 1x Prem 48, 3x expanders, 2x RKP's & 3x Speakers 1x Odyssey Sounder 4x Prestige AMDT dual-tecs 6x Impaq+ Shock Sensors 4x Impaq Break Glass 2x Exodus Fire Any "help/advice/rule of thumb" would be great. Thanks All
breff Posted June 4, 2007 Posted June 4, 2007 Following is a calculation by EN Calculator, Texecom's software for calculating power requirements: You will be best off fitting an additional PSU with an additional 7.2ah battery, use it to power part of the network, negatives must be commoned but DO NOT common positives. Power Supply Report for: bellboi PD6662 System Grade: 1 Control Panel: Premier 48 Battery Size: 7.2 Ah AC Fail Sigalled to ARC: No Required Standby Time: 12 Hours Total PSU Output: 2.00 Amps Battery Charging Current: 0.75 Amps Peak Available Current: 1.25 Amps Continuous Rated Output: 0.60 Amps Summary of System Devices Qty Description Grade Quiescent Alarm -------------------------------------------------------------- 02 Premier LCD 3 0.050 Amps 0.090 Amps 03 Premier 8XP 3 0.195 Amps 0.195 Amps 03 16 Ohm Speaker 3 0.000 Amps 0.300 Amps 01 Odyssey 1-5 (Normal) 3 0.018 Amps 0.545 Amps 04 Prestige AMDT Plus PIR 3 0.080 Amps 0.080 Amps 06 Impaq Plus 3 0.132 Amps 0.132 Amps 04 Impaq Glass Break 3 0.092 Amps 0.092 Amps 02 Exodus OH 3 0.016 Amps 0.016 Amps 01 Premier 48 1 0.070 Amps 0.070 Amps -------------------------------------------------------------- Total Current: 0.653 Amps 1.520 Amps -------------------------------------------------------------- System Summary Requirement Actual Notes ----------------------------------------------------------------------------------------- 12 Hours Standby 9.86 Hours Standby time does not meet the requirement. Max Alarm Current: 1.25 Amps 1.520 Amps Alarm current exceeds maximum available from control panel! The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
bellboi Posted June 4, 2007 Author Posted June 4, 2007 Following is a calculation by EN Calculator, Texecom's software for calculating power requirements: You will be best off fitting an additional PSU with an additional 7.2ah battery, use it to power part of the network, negatives must be commoned but DO NOT common positives.Power Supply Report for: bellboi PD6662 System Grade: 1 Control Panel: Premier 48 Battery Size: 7.2 Ah AC Fail Sigalled to ARC: No Required Standby Time: 12 Hours Total PSU Output: 2.00 Amps Battery Charging Current: 0.75 Amps Peak Available Current: 1.25 Amps Continuous Rated Output: 0.60 Amps Summary of System Devices Qty Description Grade Quiescent Alarm -------------------------------------------------------------- 02 Premier LCD 3 0.050 Amps 0.090 Amps 03 Premier 8XP 3 0.195 Amps 0.195 Amps 03 16 Ohm Speaker 3 0.000 Amps 0.300 Amps 01 Odyssey 1-5 (Normal) 3 0.018 Amps 0.545 Amps 04 Prestige AMDT Plus PIR 3 0.080 Amps 0.080 Amps 06 Impaq Plus 3 0.132 Amps 0.132 Amps 04 Impaq Glass Break 3 0.092 Amps 0.092 Amps 02 Exodus OH 3 0.016 Amps 0.016 Amps 01 Premier 48 1 0.070 Amps 0.070 Amps -------------------------------------------------------------- Total Current: 0.653 Amps 1.520 Amps -------------------------------------------------------------- System Summary Requirement Actual Notes ----------------------------------------------------------------------------------------- 12 Hours Standby 9.86 Hours Standby time does not meet the requirement. Max Alarm Current: 1.25 Amps 1.520 Amps Alarm current exceeds maximum available from control panel! Thanks Glenn, better go an buy myself another PSU and Battery
