Texecom Veritas R8 + Optex Pir & Mag Door Contacts Problem
buges
Hi
I desided to add 2 magnetic door contacts to the same zone as one of my pir's (optex rx-40qz)
When the door contacts & pir are wired up, it fails the walk test, if i disconect the pir the door contacts pass the test & if disconect the door contacts the pir pass's the test!!!
Have check every thing, no shorts in wiring, differnt zone on panel ect...
any help would be great
Thanks
Hi ,
Have you wired the contacts into the same zone as the pir ?, if so , just put them on there own zone .
You have probably got them wired in parallel.
Regards.
Guest anguscanplay
youve got them wired in parallel
but they really shouldnt be on the same " zone " as the pir im assuming you installed the whole system yourself and its not on a maintainance scheme, so all you are doing is saving problems for the future if you start to get false alarms
