Accenta 8 Alarm Crontol System
Guest Susie
Guest Susie
This is my first time posting so please be gentle - I have just moved into a property with a Accenta 8, I tried changing the user 1 set code and have ended up not being able to set the alarm at all
I have tried activating the user 2 code - no joy, the only saving grace is I have the engineers code (which is what got me into trouble in the first place)
I'd like to do a factory reset and start again from scratch - Is this advisible, or does someone know some magic keystroke that will make this better? I'd be grateful for some advice
Guest Adrian
B) Thanks Peter you beat me to it!!!
Adrian B)
Guest Susie
Isn't the internet Great!! Adrian, Peter Thanks - I'll have a play tomorrow
With the later Accenta you can change the user code using the engineer code. Press Prog enter Engineer code then press 8 (leds 1 to 4 should be then lit )
press 1 to change user code 1
press 2 to change user code 2
enter the new user code then press reset three times.
jpaul
Guest Susie
thanks for the addittional info JPaul I'll try when I get myself home - no doubt I'll be back on later if I have any probs
Thanks all
