Chorlton Posted June 14, 2007 Posted June 14, 2007 You should do stand up!!! AVtech i have sold 100's and had less than 1% return..... Also use it myself in my store!!! So just under a 1% failure rate is OK with you If just under 1% of the equipment I sold was faulty I would change supplier immediately cheap = nasty. budget equipment = budget job VALUE is what's important.
Guest anguscanplay Posted June 14, 2007 Posted June 14, 2007 You should do stand up!!! AVtech i have sold 100's and had less than 0.1% return..... Also use it myself in my store!!! you ever needed to use the captured footage as evidence - im not just on about AVtech here - get it installed by an approved contractor DIY cameras are fine to watch the kids playing in the yard but thats about all imo
Algon1 Posted June 14, 2007 Posted June 14, 2007 QFA theres a lot of dodgy far eastern stuff out there, mostly sold on the tinternet. Loads of people wasting money on it too, but that dont make it any better. Ive installed loads of cctv, and a fair bit of domestic cctv too, if you budget between
Guest anguscanplay Posted June 14, 2007 Posted June 14, 2007 QFA theres a lot of dodgy far eastern stuff out there, mostly sold on the tinternet. Loads of people wasting money on it too, but that dont make it any better.Ive installed loads of cctv, and a fair bit of domestic cctv too, if you budget between
DownUnderCamMan Posted September 11, 2007 Posted September 11, 2007 This little gem won't break the bank & has the features you want. Just not sure where you can purchase in the UK??? Try Norbain... x4 Channel DVR & 8" LCD combined. CD Burner built-in Fit your own IDE HDD Ethernet & software provided It even plays AVi's & JPEG's through a SD card input... http://www.tvs.com.tw/lr804j.htm Beware the fury of a patient man...
BestGear Posted September 11, 2007 Posted September 11, 2007 ...Geovision is hard to beat for home or business use... as long as you are computer literate. I have several GV systems running and they get rebooted about twice a year - run fine under XP (an nothing else running on them...).... XP gets unreliable the more stuff thats installed on it... so choose carefully what and when you install...inc windows update if the box is internet accessible... DJ
alterEGO Posted September 11, 2007 Posted September 11, 2007 i am looking to install a cctv system in and around my home, i want something that wont break the bank but i want something that is good! i would like to be able to connect it to my broadband connection and be able to record to a hard drive as well as being able to access from all over world if need be (hence the broadband connection)?can anyone help please? after reading this, how has the O/P got full trade?
Guest anguscanplay Posted September 11, 2007 Posted September 11, 2007 after reading this, how has the O/P got full trade? cause he`s another fire engineer thinks its easy to do it all but a black art to do his trade - its still only connecting by numbers all said
kensplace Posted September 17, 2007 Posted September 17, 2007 Geovision is good, but pricey, especially the higher end cards. AVtech is budget, low end. Dont expect any decent results without spending some good money, and either expect to spend a lot of time learning, or money paying someone to get the best results.
baywatch Posted September 18, 2007 Posted September 18, 2007 For a while now we have been using the Avermedia 4 camera DVR which we find works well over the Internet and seems reliable. Only glitch really is the lack of a masking facility on the motion detection, otherwise nice little unit with a 2 year warranty.
