dbeattie Posted June 16, 2007 Posted June 16, 2007 Hi Guys. was wondering if anyone might be able to help. Have an Optima XM. The "power" and "day" led's are lit as per normal, however when I enter my code nothing happens. It appears the code is no longer recognised. I have tried code change,alarm tests and alarm memory recall but as the system is not recognising my code I cannot do anything. The unit has been working fine and has not been tampered with in any way. Any advice on how to get the system working again would be much appreciated. , Dave
Guest anguscanplay Posted June 16, 2007 Posted June 16, 2007 Hi Guys. was wondering if anyone might be able to help. Have an Optima XM. The "power" and "day" led's are lit as per normal, however when I enter my code nothing happens. It appears the code is no longer recognised.I have tried code change,alarm tests and alarm memory recall but as the system is not recognising my code I cannot do anything. The unit has been working fine and has not been tampered with in any way. Any advice on how to get the system working again would be much appreciated. , Dave me bets youve had a recent power outage needs a new battery and a service , ring a couple of local ALARM firms and see who offers the best value
barooga Posted June 16, 2007 Posted June 16, 2007 me bets youve had a recent power outageneeds a new battery and a service , ring a couple of local ALARM firms and see who offers the best value Would definitely recommend above advice has the panel may now have developed a problem. Not unknown on this kit. Growing old is mandatory, growing up is optional
dbeattie Posted June 16, 2007 Author Posted June 16, 2007 blimey that was quick! Thanks guys. Yes, you are right. Mains Electric went off today with the bad weather. Never really thought that might have caused the problem as over the years this kind of thing has never affected the alarm. As you can tell I'm a bit of a thicko on these things but Just wondering why you think the battery needs replacing. Will heed your advice and call a few alarm engineers later today. Thank You once again for the advice
Guest anguscanplay Posted June 16, 2007 Posted June 16, 2007 blimey that was quick!Thanks guys. Yes, you are right. Mains Electric went off today with the bad weather. Never really thought that might have caused the problem as over the years this kind of thing has never affected the alarm. As you can tell I'm a bit of a thicko on these things but Just wondering why you think the battery needs replacing. Will heed your advice and call a few alarm engineers later today. Thank You once again for the advice the battery is stuffed - trust me ive changed loads today but when the power comes back on the panel tries to charge the battery as well as doing all the other stuff it needs to do , cant cope and throws a wobbly
dbeattie Posted June 16, 2007 Author Posted June 16, 2007 the battery is stuffed - trust me ive changed loads today but when the power comes back on the panel tries to charge the battery as well as doing all the other stuff it needs to do , cant cope and throws a wobbly No worries. I think I will try and replace the battery myself. If that doesn't work will call an engineer in. I assume the battery change is a fairly simple procedure?
Guest anguscanplay Posted June 16, 2007 Posted June 16, 2007 No worries. I think I will try and replace the battery myself. If that doesn't work will call an engineer in. I assume the battery change is a fairly simple procedure? unless its rebooted itself too
dbeattie Posted June 16, 2007 Author Posted June 16, 2007 unless its rebooted itself too what will a "re-boot" do?
Guest anguscanplay Posted June 16, 2007 Posted June 16, 2007 what will a "re-boot" do? loose all its programming, get an engineer in to check it all out then you know its good for a few years more - unless the charging resistor has blown as well
dbeattie Posted June 16, 2007 Author Posted June 16, 2007 loose all its programming, get an engineer in to check it all out then you know its good for a few years more - unless the charging resistor has blown as well That doesn't sound good! I am going to go with the new battery install. Hopefully that will work. Think I will have to make a few enquiries and get the thing serviced. Yo be honest we inherited it with the house some 17yrs ago and this is the first time there has been a problem with it. thanks for taking the time to help a newbie. dave bt
