njk57 Posted June 16, 2007 Posted June 16, 2007 Hi, I am a local handyman & one old lady that I do work for has an alarm in the house that was present when she moved in 2 years ago. There is no manual or paperwork on the system & no code numbers. The flap has a label inside for a service phone number but none is given. The only ID is the number 9800 on the front. I am trying to find out: 1. The make (neighbour thinks it may have been Bulldog) 2. Where can a manual be sourced? 3. How does she go about getting the code or setting a new one? At present she has no security. Can anyone help? Thanks, Nick
nikko Posted June 16, 2007 Posted June 16, 2007 Indeed, a scantronic 9800. If she does'nt know the present code she'll need an engineer to reset the codes for her. Then a new code of her choice can be set-up. I'm just down the A50 and visit Derby quite often. If you like, give me a call on Monday. 07917 017160, Steve. I went up into the attic...I found a Stradavarius & a Picasso. Unfortunately..... Stradavarius couldn't paint, and Picasso made a shocking fiddle. My Facebook page...http://www.facebook.com/home.php#/profile.php?id=1279556853&ref=name
Guest anguscanplay Posted June 16, 2007 Posted June 16, 2007 and dont be tempted to " not bother " as when the battery goes it will sound to let her know and without a code she`s stuffed
whistle Posted June 16, 2007 Posted June 16, 2007 and dont be tempted to " not bother " as when the battery goes it will sound to let her know and without a code she`s stuffed And always seems to be at 3AM rkp showing bF .
Guest anguscanplay Posted June 16, 2007 Posted June 16, 2007 And always seems to be at 3AM rkp showing bF . always 3am
Barsnake Posted June 17, 2007 Posted June 17, 2007 And The Customer Tells You They've A 6F And At 3am It Takes A Little Longer To Twig There Was A Derby Firm Called Bulldog I Believe They Are No More But There Is A Bulldog Firm Around Now In Derby But I Don't Believe There Linked
