xass2 Posted June 16, 2007 Posted June 16, 2007 Moved into a house with one of these fitted. Zones 1-7 used. All fine till i cut the cable for the panic alarm. Rejoined cable and insulated while otside bell box made a siren noise. Lasted 10 mins. Now no noise from panel. Still shows up active zones when code typed in but won't trigger off with movement. Tried to omit zone with panic alarm, but won't programme. Tried most stuff in manual. Would be grateful of any advice before paying the earth to call someone out Rich Wakefield
Guest anguscanplay Posted June 16, 2007 Posted June 16, 2007 Moved into a house with one of these fitted. Zones 1-7 used. All fine till i cut the cable for the panic alarm. Rejoined cable and insulated while otside bell box made a siren noise. Lasted 10 mins. Now no noise from panel. Still shows up active zones when code typed in but won't trigger off with movement. Tried to omit zone with panic alarm, but won't programme. Tried most stuff in manual. Would be grateful of any advice before paying the earth to call someone outRich Wakefield sound to me like you blown a fuse
breff Posted June 17, 2007 Posted June 17, 2007 Press RESET? The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
Guest anguscanplay Posted June 17, 2007 Posted June 17, 2007 unless it was the cable to the bell and not the panic button
breff Posted June 17, 2007 Posted June 17, 2007 unless it was the cable to the bell and not the panic button More likely. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
gooner31 Posted June 17, 2007 Posted June 17, 2007 Panic buttons shouldnt be programmed to be omittable.Also panic buttons dont have a pos/neg connection.Are you sure it wasnt the bell cable you accidently cut i would re check you joint in the cable if you still cant sort the problem i would recommend you call the services of a local engineer yellow pages could be a good place to look for one. pete ................. Any comments/opinions posted are my own and not that of my employers.
Guest anguscanplay Posted June 17, 2007 Posted June 17, 2007 you still cant sort the problem i would recommend you call the services of a local engineer recommend that anyway to ensure its been done correctly
xass2 Posted June 22, 2007 Author Posted June 22, 2007 recommend that anyway to ensure its been done correctly Thanks all you guys for this help. I've called the engineers out, there's definitely a blown fuse, but i replaced it and it still won't reset. Rich
alterEGO Posted June 22, 2007 Posted June 22, 2007 unless the installer was a naughty boy and connected the sab through the button, so when pressed in caused the sab to activate. wouldn't be the first time i've seen it done. or he may have used spare cores off the bell for the panic.
