prowleralarms Posted June 18, 2007 Posted June 18, 2007 hi all, i have a client that wants to be able to monitor 8 cameras at 2 of his works from his own home, i would be like to hear your views or suggestions as to a good set up with a decent frame, rate relliable etc.
Alpat Systems Posted June 18, 2007 Posted June 18, 2007 hi all, i have a client that wants to be able to monitor 8 cameras at 2 of his works from his own home, i would be like to hear your views or suggestions as to a good set up with a decent frame, rate relliable etc. Does the client currently have: DVR ADSL (at both home/work) If its a new install, I'd recommend a DVR365 www.dvr365.com
prowleralarms Posted June 18, 2007 Author Posted June 18, 2007 he has adsl at both places but is at present using time lapse video
baywatch Posted June 19, 2007 Posted June 19, 2007 We have customers with 16 shops who use Geovision systems which are quite user friendly over the web. He can also watch many shops at once on split screen.
prowleralarms Posted June 19, 2007 Author Posted June 19, 2007 what geovision kit would you reccomend
baywatch Posted June 19, 2007 Posted June 19, 2007 Depends on the frame rate you require, but for normal retail then the GV600 card is usually more than adequate.
