Vertias R8+ Double Beeps?
timothy
Hi ,
Do you have a pir or a contact on your exit zone ?, if its a pir , then you are probably getting odd triggers and settling while the alarm is counting down the exit beeps, this should show on the display as an led on.
Just make sure the alarm sets.
Regards.
Thats normal, it changes to the single beep when zone 1 (prob front door) becomes active.
  • 2 weeks later...
