jayrule Posted June 20, 2007 Posted June 20, 2007 Hello all, i am a new member and I am not an alarm engineer. The alarm i inherited with my house is an SL Compact. While cleaning the panel today a bunch of lights lit up. I pressed the reset button and all seemed fine. Now when i walk into the kitchen (Zone 3) , the control panel goes "bleep". It does this every time i activate the sensor. i dont have a user guide and have tried downloading the SL8 one from this site however it no longer seems to be on the server. The alarm sets and arms all zones as it should but obviously very annoying when i keep setting it off. Any ideas? many thanks jamie
FASTCAR Posted June 20, 2007 Posted June 20, 2007 Hi , You have turned on the CHIME feature , press CHIME , then 3 (led goes off)...
jayrule Posted June 20, 2007 Author Posted June 20, 2007 Hi , You have turned on the CHIME feature , press CHIME , then 3 (led goes off)... Thankyou fastcar. You the man. J
arfur mo Posted June 20, 2007 Posted June 20, 2007 Thankyou fastcar. You the man. J and if emits a short squeak at about every 5 minutes then it's your smoke detector/s battery - not the intruder alarm trust em i get more far more calls per year for battery smoke detectors giving off a flat battery signal than any other fault call - and i won't even fit them but will they listen mumble! mumble! then they ask will come out now and go and fit new batteries for them - a 3am i the morning? bet they would just love that bill regs alan If you think education is difficult, try being stupid!!!!
