Hello everyone
Guest Electrotec
Guest Electrotec
My name is John and I run the Electrotec Security Supplies web site. I did a previous post but I had something on the left that said warn, is this normal or have I done something wrong. :rolleyes:
We all have the Warn Bar beside our names, everyone can only see their own.
Dont worry about it unless it starts going up, thats when you know you're being a naughty boy!
Guest Electrotec
Just found an explanation in a posting made by Waza04. The only other thing that I do not understand is that the little envelope on the left of the new topic has a small dot on it like a seal. Although I have seen a list of all these different coloured envelopes with explanations of each one, this particular one is not listed. :unsure:
Guest Electrotec
Thanks for that Breff, do you know what the little envelope with a dark grey dot on it means?
Guest Affinity
where is the little envelope John? Do you ; mean the mini profile
Guest Electrotec
Hello Linda,
if you click your browser back button you should see it in the left hand column next to each title topic. Most are blue but some are orange, mine is blue with a dot, there is no description of what the dot signifies.
This is a link to the image I think :blink:
Hello Electrotec, hope this helps.
"The Explanation of the Envelopes"
f_norm.gif =Open Topic (new replies)
f_norm_no.gif =Open Topic (no new replies)
f_hot.gif =Hot Topic (new replies)
f_hot_no.gif =Hot Topic (no new replies)
f_poll.gif =Poll (new votes)
f_poll_no.gif =Poll (no new votes)
f_closed.gif =Locked Topic
f_moved.gif =Moved Topic
Sorry, forget to answer you question about the DOT`s, basically if they have a DOT on the Envelope it means you have posted (participated) in that certain forum thead...
Guest Electrotec
I was beginning to think it may their to help you locate your own posts more easily, your last post has confirmed that.
Thanks for your help :)
Guest Keiko
Hello to every one!
reged on here 12, maybe 18 months ago but not many people here then.
Cant remember my login name or pass word so i am here again.
A big hello to all fellow engineers and a warm welcome to all new engineers.
Good luck with the trade, I started in 1996 and it only gets worse!!
Ian. (keiko)
